E nr : WH 35830/01 FD 730701495
hello,
I'm looking for as much info as possible on the motorcontrol printed circuit " AKO 544 220" .
I already found on your forum that the triac BTB 15 is to be replaced by a BT139. Furthermore I'm looking for info about the Philips IC
AKO450380 / 31655NE / MSM93181 wich is located near to the Triac.
I found a six wired " grey" cabling between the motor and the printed circuit.
What is to be measured on this cabling to be sure about the motor condition ?
Thank you for any answer and friendly greetings
pol
belgium
